I never mentioned anything about idiots and I don't think that's appropriate language for the forums. Please be constructive.
Therefore your installation is potentially dangerous and should be turned off until it's made safe.
The idiots I was referring to , are the 2 electricians that came and visited my property and no one on this forum
I am sorry, but if an installation is unsafe, they should make this clear immediately. The last one, didn't want to replace the CU, didn't want to do any work, and then said my earth to the spike was too thin at 6mm and needed 10mm even though it is not buried in the ground!
I might turn off the power from the isolator I have at the moment and replace the CU with the one I have. I then worry about the tail upgrade later on as currently the tails at 16mm will be more than ok for my current setup.
Thanks for the heads up.
