So when it comes to providing a new socket, then yes, BS 7671 does allow RCD protection to be omitted in certain circumstances.
Yes, and what are those circumstances? That the socket is provided to supply a specific piece if equipment and is so labeled.
Whether you, I, or anybody else might consider it appropriate to omit the RCD if the piece of equipment would function perfectly well with it is immaterial to the question of whether it complies with BS7671 when BS7671 doesn't include such consideration as a condition of the exemption.
We weren't talking about what you or anyone else considers to be best practice, only about whether the result complies with BS7671.
In the case of the router-under-the-stairs scenario, the socket is being provided with the intent of supplying that specific piece of equipment,
Why does the equipment need a non-RCD socket? You are the designer. You are exercising your skill and care. What reason do you have for deciding that an RCD protected socket would be inappropriate for the router?
As I said already, a cost vs. benefit assessment. It's one socket, provided with the intent of feeding a specific piece of equipment, for which the absolutely tiny increase in safety RCD provision would provide may not be worth the cost of such provision compared to just running a few feet of cable to a regular socket.
And how, as designer, do you ensure that your work remains compliant? If compliance depends on the socket being used to supply only that specific piece of equipment, what can you do to make sure it is only used for that?
You don't have to do anything. Obviously the designer/installer cannot be responsible for what somebody might do later.
so if you label it as such it complies with BS7671. You've just acknowleged such, yet earlier you said it wouldn't be compliant.
What did I actually say?
In response to Andy's comment, I said:
PBC_1966 said:
AndyPRK said:
One recent thread which comes to mind (IIRC) is that someone wanted to fit a socket under their stairs to power a router.
And which, apparently, even under the current "holy grail" of BS7671 would still be compliant without RCD protection if he just stuck a Dymo label on it saying "For computer router only - Not RCD protected" or something similar.
To which your reply was:
ban-all-sheds said:
But then after you said that you need some specific reason and I asked you if BS7671 actually contains any such requirement in the exemption clause your reply was:
ban-all-sheds said:
PBC_1966 said:
and ask again if BS7671 says anything about needing a specific reason.
It does not.
Again, remember this issue arose not on the basis of whether anybody might feel that it's a best practice, a good idea, or anything like that, only whether providing a socket for a specific piece of equipment and so labeling it would be compliant with BS7671.
ban-all-sheds said:
If you are going to rely on the intended use, then how do you satisfy yourself that the intended use is the only use that there will ever be?
Where does the exemption clause say that you have to? All it says it that the socket is
intended to supply a particular piece of equipment. It doesn't say that you have to be satisfied that it will
never be used for anything else, which for a regular BS1363 socket would obviously be pretty much impossible to guarantee.
Back when BS7671 required RCD protection only for sockets which might "reasonably be expected" to be used to power portable equipment outdoors, were you claiming that sockets even on the second floor of a building would still need RCD protection to be compliant unless you could be satisfied that they would
never be so used? (Allowing for the fact that somebody
could, quite easily, drop an extension lead out of an upper window.)
