Is there, or is there not, still a specific RCD exemption in BS7671 for a socket installed for supplying a particular piece of equipment and which is so labeled?
You have to have a sound reason. You can't justify omitting the RCD just because it's convenient to do so.
Did you miss my request in reply to this? Or did you think that responding would not support your view so decide to ignore it? I'll be charitable, assume it was the former, and ask again if BS7671 says anything about needing a specific reason.
I'm not absolutely certain of the answer, by the way, as I don't have a copy. The online references I've found to 411.3.3 quote only the requirements I outlined already, so it would seem that they are the only requirements for the omission of RCD protection, but perhaps there's another part which adds your "sound reason" requirement. If so, let's see it.
It could also mean that they felt that the existing requirement was no longer adequate to make reasonable provision for safety wrt installing new sockets.
It could. But given that they clearly don't regard existing unprotected sockets as any sort of danger, it seems unlikely, otherwise If they suddenly decided that sockets without 30mA protection were no longer to be considered reasonable provision for safety, then they would have suggested coding such in existing installations with something which indicates potential danger. They didn't.
And now you're introducing another opinion that it is about vital safety, and not merely increased safety.
vital. adjective. Of or relating to life.
O.K., if that's the way you intended it. But I'm sure you know it has a slightly different meaning as well.
But you are the one who is trying to claim that it is not illegal without anything to support that claim.
As JohnD first mentioned above, English law (and American, and just about everywhere else which adopted the fundamental principles of English law) works on the basis that you are permitted to do anything which is not expressly forbidden. You don't need laws telling you what you
are allowed to do.
What is there one could do to support a claim that something is legal short of pointing out that there is no law which explicitly states that it isn't, and no precedent set in case law regarding interpretation of some act which has deemed it to be so? And in this case, probably not even one case brought to court for somebody fitting a new socket without RCD protection in his own home, unless you know differently.
As I have pointed out already, not making reasonable provision etc is expressly forbidden by law.
Nobody is disputing that - The law states so quite clearly and unequivocally.
What the law does not state clearly and unequivocally is that not providing 30mA RCD protection on a new socket means that you have not made the required reasonable provision for safety. That is your opinion.
