And don't forget, for every potential kW of wind energy, we have to install a kW of combined cycle gas turbine generation to run when the wind is too weak or too strong.
Also to make us a bit more independent from the Middle East when our own oil runs out.In real terms wind farms are a political move to generate work, it was never to generate power, just to generate work.
Which they don't really do.Also to make us a bit more independent from the Middle East when our own oil runs out.
Not sure about combined cycle gas turbine as takes around 12 hours to reach full output and 24 hours to close down again. Even the high pressure water reactor is faster than that. The gas soon starts to generate but you don't get steam straight away and they need warming up slowly. The electric mountain is the answer. Some of the hydro power stations are over 100 years old and still running only the transformers have changed. The Glaslyn and Llyn LLydaw lakes in Snowdon powered a hydro power station built to supply the radio transmitter some where near Waunfawr the radio transmitter is long gone but the power station is still running. It looks like a church looking down from the A498.And don't forget, for every potential kW of wind energy, we have to install a kW of combined cycle gas turbine generation to run when the wind is too weak or too strong.
Usually less than an hour Eric. Can be started even faster but with some loss of efficiency.Not sure about combined cycle gas turbine as takes around 12 hours to reach full output and 24 hours to close down again.
Thats from standstill (actually Wikipedia says 75s). From spinning reserve - that's with the machine spinning but the turbine drained - it's 16s. That's impressive - 0 to 1.8GW in 16s.... Dinorwig power station built when I was just a lad (1972) fills the gaps when other stations can't it cost so much that only a government could build one, 1,728MW from standstill in just 90 seconds ...
Impressive, indeed, and good to visit.Thats from standstill (actually Wikipedia says 75s). From spinning reserve - that's with the machine spinning but the turbine drained - it's 16s. That's impressive - 0 to 1.8GW in 16s.... Dinorwig power station built when I was just a lad (1972) fills the gaps when other stations can't it cost so much that only a government could build one, 1,728MW from standstill in just 90 seconds ...
It is indeed. It's a lot of years since I last went there.Impressive, indeed, and good to visit.
Exactly, which is why anyone should take with not a pinch of salt but the entire packet ... claims by the renewables brigade that all we need is another Dinorwig or twoBut it's a bit like a drag racer - incredible acceleration, but it can't keep going for long.
And that is the issue. Most of the plant currently installed does not like the thermal stresses from rapid starts and/or rapid load changes. It's not that they can't do them, but it adds significantly to the wear and tear on the plant and that manifests itself in increased maintenance costs. Open cycle are a bit better in that respect, but mostly gain from being cheaper plant in the first place.... if you still want to be able to use it next week.
A bit like the way the launch control systems in BMW M# cars limit how many times in quick succession you can try toMost of the plant currently installed does not like the thermal stresses from rapid starts and/or rapid load changes. It's not that they can't do them, but it adds significantly to the wear and tear on the plant and that manifests itself in increased maintenance costs.
