Do smart meters have inbuilt isolators?
Status
Not open for further replies.
Which is not a surprise really. Given the pressure they are under to get them fitted, or at the least offered, to everyone - that's one way of meeting your target and dodging the fines.
Indeed.
However, you will realise that my point was that it's not quite true to say that getting a 'smart' meter cannot result in reduced costs (whereas changing supplier can), if one can only change to suppliers with the cheapest tariffs if one agrees to have a 'smart' meter!
Kind Regards, John
SM isolation does not provide a safe means of isolation to change the CU
As has been said, 'smart' meters do not contain 'switches' that can be locally operated.
In any event, as has been said (or, at least, implied) a relay with NC contacts (which is what these meters do contain) would never be acceptable as a means of safe isolation, for fairly obvious reasons, even if they could be locally operated.
Kind Regards, John
posts relating to a different problem have been moved away.
Hey, Ill fit the aforlinked isolater..lol
BTW what happens if it cannot get a signal? (like foil wrapping?)
It is obviously theoretically possible that smart meters could eventually result in some saving of cost, if it facilitates cheaper electricity at times of lowest demand, but that's not happening at present, and may well never happen (probably quite the converse!!).
Actually that has been implemented by Octopus Energy.
Yeah, John said that over a year and a half ago. Unfortunately the thread was brought back to life instead of a new one being started.
Sounds like a good reason not to accept a 'smart' meter. I should threaten the people who fitted the meter with legal action if they don't come and fix it. Not that it'll do a lot of good.
I'm not too sure why you're commenting on something I wrote nearly 18 months ago but, in any event, you may have overlooked my subsequent (again almost 18 months old) post ...
.... However, you will realise that my point was that it's not quite true to say that getting a 'smart' meter cannot result in reduced costs (whereas changing supplier can), if one can only change to suppliers with the cheapest tariffs if one agrees to have a 'smart' meter!
Kind Regards, John
Status
