What is this mysterious research, and why does it fly in the face of common sense?Lads, this valve lark is causing me some consternation, so I've done a bit of research on the internet. It seems the ABV is needed when a CH system is fitted with TRV's in order to maintain flow through the boiler when the TRV's shut down.
The flow to each rad connects to the flow from the boiler, and the return from each rad joins the return to the boiler, so opening a rad valve doesn't affect the resistance of the distribution pipework, other than to introduce turbulence.
Why do you think that shutting a TRV, or any rad valve, will impede the flow through the distribution pipework?
pure tosh
