The same thing that makes me think that you won't give an honest answer.What makes you think that I am?
The same thing that makes me think that you won't give an honest answer.![]()
Would I lie to you???The same thing that makes me think that you won't give an honest answer.![]()
Gotcha, a plumber with his brains blown out.I am, however, the heating god.
Hmmm, you are being a bit thick tonight... I'll let someone else explain the difference between a plumber and a heating installer or a refrigeration engineer... Take your pick from the twoGotcha, a plumber with his brains blown out.![]()
Brains blown out and a fragile ego to boot. I think your ego needs another name change.Hmmm, you are being a bit thick tonight... I'll let someone else explain the difference between a plumber and a heating installer or a refrigeration engineer... Take your pick from the two
Surly, the only reason that I would need to do that is if I had been banned.. As it is I shall remain Firebrand. Would you prefer that I change my name to Corgigrouch? You seem to have a thing about himBrains blown out and a fragile ego to boot. I think your ego needs another name change.![]()
But that's the reasoning that proves that torture doesn't work. Because you assume/know that your vicitim is lying, you never accept it when they tell the truth, and you keep on torturing them till they start telling you what you want to hear, and you then get the lie that you want, rather than the truth
And there I thought, you'd admitted months ago , that you were indeed Himmagain? Strange that you should now state that you're not some re-incarnated contributor.You might be a recon of a previous twisted contributor, but I am not.
teacher I think ???
WTF has that got to do with addressing an habitual liar? My reasoning was concluded from the fact Firegrouchcorgi rarely tells the truth.But that's the reasoning that proves that torture doesn't work. Because you assume/know that your vicitim is lying, you never accept it when they tell the truth, and you keep on torturing them till they start telling you what you want to hear, and you then get the lie that you want, rather than the truth
And it is impossible for you to reason anything as you have no idea what truth is... Hell, you don't even know the difference between a gas fitter and a plumber.WTF has that got to do with addressing an habitual liar? My reasoning was concluded from the fact Firegrouchcorgi rarely tells the truth.
You probably would if you had half a brain...... I would think.
