I disagreeFWIW if it was built in 1977, and has white twin and Earth on the sockets it’s almost certainly 2.5 mm / 1.0 mm
I disagree
Sorry John I do not agree "anybody saying a rewire is required without doing any testing needs be shown the door".
First of all, the most important piece of equipment to use - the Mark One Eyeball. Sometimes can indicate it needs a rewire, sometimes indicates it might not need a rewire (although might indicate a few fixes or sometimes indicates it looks ok so far). That equipment is the first thing, a look around at what is.
Then, again the Mark One Eyeball and this time we will open a few things up to have a better look (sockets, switches consumer unit). Again we might think one of the three options above might apply.
Either of these might lead us to confirm or suspect it might well need a rewire.
If we need further info then testing occurs.
I do not do much in the way of PIRs/EICRs but on occasions I have there are a few I have cut short and reduced my fee accordingly because I have concluded a rewire required in full or in part, without any testing.
That will only be because the rules about size have changed - nothing to do with its condition.aside from the bonding.
It was the remark about wire insulation lasting 25-40 years that made me question it a bit since i dont think people have rewires every 20 years.
I'm not sure when the 2.5 CPC was upgraded to 1.5. I think it was the mid 80s. That came about because of an issue with protection by BS 3036 fuses.Our house is about that vintage and was 2.5 / 1.0 before being refurbished
The other is green goo.The main things that could lead to a rewire on an installation from the 70s are if its been bodged about with too much by DIYers or kitchen fitters over the years (easier sometimes to start again if there is too much bodgery) or if you are wanting a load of extra points in all the rooms and its easier to just start fresh rather than to add on all over the place, although this might be limited to some areas (i.e. complete kitchen refurb might be done as new power cirucits for just that area, and joint the existing ring through)
said what he had looked at seemed fine, aside from the bonding.
I was perhaps not clear enough. I was not agreeing with the comment as a generalisation but, rather, in the context of a house built in 1977 and wired with PVC cable. I also 'assumed' (I know!) that 'testing' would also include at least a cursory visual inspection (with the 'Mark One Eyeball'), whereas we are told that "...Sorry John I do not agree "anybody saying a rewire is required without doing any testing needs be shown the door".
Do you really believe that an 'electrician' should not be 'shown the door' if he/she declared that a complete re-wiree is needed, of a 1977 house with PVC wiring, purely on the basis of just looking at the 'fuse box' ?..... he literally looked at the fuse box and told me 'rewire needed'
and that doesn't have to be upgraded, retrospectively - though advisable.
Silver Jubilee year 1977 we added a temporary feed for an event which was white 2.5mm² and after we recoiled it on a bigger drum, the same thing happened for golden Jubilee with the same length of cable and it was finally 'used up' for some 13A theatre dimmer lighting circuits 2007.AFAIR, white twin and earth (not LS0H) started appearing in sheds in the 80s.
But certainly, I would expect late 70s-installed cable to be metric.
Possibly but depends on the works being done.Not sure I agree with that. Any spark changing circuits or adding them would need to confirm earthing and bonding are up to spec
