The current created by the "booster" transformers is not part of the circuit returning the motor current back to the sub station. That return circuit for the traction power is a very diffused ( many parallel paths ) route through the earth and other conductors.
The current created by the booster ( miss named ) tranformers in the cable is equal to and flows in the opposite direction to the current in the over head wire supplying the trains. The cable is run as close as possible to that over head wire ( but still several feet away ) so that the magnetic fields created by the two currents cancel each other out. Before "boosters" and the "counter current" wire were used all cables along side or close to the track had very large voltages induced in them when an electric train went past. This created serious problems for signalling and communication designers and engineers.
