What have you bought today?
Why?
Malleability = too easy for it to bulge under pressure?
Irrespective of the pipe material, a regular test of mine, before leaving my garage, is to stand as hard as I possibly can on the brake pedal, with engine running. Far more pressure than I could possibly apply once on the road. If they are going to bulge, or burst, it would happen safely whilst stood. I do at the moment, have most of the pipework length swapped to copper and have never had copper bulge or burst.
I’ve had hoses and pipes burst about a dozen times during my time as a tester using that method when carrying out a mot test.
I have only had it happen once, and it was on the road, on a downhill, with a single circuit braking system, early in my driving career. Very scary! Which why I now conduct my regular static test.
Afaik there are different grades of copper for brake lines
I had a reel that was fairly stiff compared to soft copper that one uses in plumbing ?? As John D said
It had some type of alloy added to it afaik
Not sure if the actual pressure that occurs in a brake line when braking hard
Saw some thing that said 2000 psi ????
Kunifer was the stuff to use, iirc.
Doesn't work harden as readily as copper.
Some 6mm galv threaded rod. I bought a used pair of roof bars for the car, just assuming they would fit. It turned out that the bars were designed to clamp onto the body, at the door edge - which simply would not work on my car. My car is designed to accept bolted on roof bars, it has 4x 6mm attachment points, for a roof rack.
I tried various ideas to safely attach them, nothing worked, so the final solution is long bolts (threaded rod) via a drilling through the horizontal bar, screwed into the proper attachment points in the roof.
