Halogens are just tungsten filament lamps in a halogen-filled (quartz or other hard glass, the halogen scouring the tungsten off the glass to redeposit on the filament) and will have the same life issues with voltage.Does anybody know whether "modern" lamps - LED, halogen etc or even fluorescent, are more or less tolerant of under or over voltage?
30-odd years ago buying a bulb was straightforward, nowadays there's a huge choice!
(I had a chart somewhere once upon a time showing lifetime, colour temperature and brightness with voltages...)
Fluorescents have a similar life issue to do with the heater filaments at the ends. (Any resistive heating element is going to have reduced lifetime by running hotter due to higher input voltages).
Modern leds should be highly tolerant of voltage changes --- indeed some are rated to run from 100V to 250V or more,I believe? But some designs will be better than others, and component cost cutting can be taken too far.
