Well, if it works with buses .....wow wait for 3 minutes then 3 come together
Kind Regards, John
Quite so. When we first started arguing about tis issue, many years bacx,I undertook an informal survey of a goodly number of my 'friends and family' - and not a single one of them had ever even considered the possibility that it might not be 'correct' to plug two 13A loads in to a "!3A Double Socket".I was afraid of that. Pray tell, how would that stop a Mr.Public plugging in 26A.
It wouldn’t. In the same way you cannot stop him plugging in two unfused two way adapters and then four 13 amp loads.I was afraid of that.
Yes, that's fine.https://www.cef.co.uk/catalogue/pro...kOoff1_PEnpq2BquSncaAohgEALw_wcB&gclsrc=aw.ds
Thanks all, going with this as it matches the other sockets. Would appreciate a final confirm please!
Well - it might occur to some that 4 x 13A may not be advisable in 2 x 13A.It wouldn’t. In the same way you cannot stop him plugging in two unfused two way adapters and then four 13 amp loads.
Technically there is nothing electrically wrong with two single outlets on an unfused 2.5mm² spur but for some reason the rules say no - and people will argue that in the future someone might swap one of them for a Hadron Collider.
Not a valid reason as I indicated. People do all sorts of stupid things.Indeed it used to be permitted to add two single sockets as a spur from the ring. The problem was that such single sockets often got changed to twin sockets at a later date. Therefore you might 3 or 4 outlets on one bog standard spur thereby inviting possible overload.
I did not make that mistake.So the rule then became one twin or one single on a (unfused) spur. Of course if you spur to an (switched or unswitched) Fused Connection Unit then onto multiple socket of any quantity then this is ok. People often started to call an FCU a spur which it is not and then this creates misunderstandings . It is that part of the circuit that is actually the spur (think of trains and spurs on mainline tracks might help)
Views about this seem to be very polarised, and sometimes fairly passionately held.If I was wiring a circuit/ building from scratch, I wouldn't entertain a ring final.
You do - and for the same reasons I've described for 20A radials, I would not be particularly 'comfortable' with multiple 16A sockets on a 16A circuit.Some of us only have 16A radials and 16A outlets.
