After 23 pages a recap of the best bits is worth while..
Anyway Mattie's last picture's worth a thousand words. Well done.
Bonkersbill, your cheapest option is cross over the pair of pipes over in the cylinder cupboard just where the 28mm changes to 22mm prior to the air seperator and on the return from the cylinder. Then balance your rads to get the best out of downstairs rads. Worst case you'll need to resize 15mmm to 22mm rad feed for downstairs running in conduit. What's happened is when the systems been converted from gravity HW to fully pumped, the installer's guessed the wrong 28mm pipe as the boiler return. In their defence it was probably plumbed in wrong to the cylinder at the very beginning and they haven't first checked.
No & no.doitall said:Almost certainly a wiring fault, if Bill preferably posts the pics to me we can get it up and running in no time.
Nodoitall said:Still say it's a wiring fault.
Nodoitall said:Wiring fault No1 perhaps.
Your wavering, though nice for BonkersBill to know you've ruled out the only other possibility: operator error.doitall said:Maybe a system and electrical fault or either.
Nodoitall said:Most likely problem is the MV not moving to HTG only or the boiler pump not switching.
Everyone wasn’t forgetting but then how would you know? given you claim …doitall said:Why is everyone forgetting the heating works perfectly when on with the hot water.
Are you sure?!doitall said:I haven't read any of the previous posts, maybe skimmed a few but thats all.
Most of the time I prefer to form my own opinion.
No. Re-read the OP it was screaming 'circulation' problem from the "boiler will only come on for 30 seconds" bit.doitall said:….the original post [is] typical of an electrical fault.
I would almost say the pump is wired wrong
No, there weren’t any.doitall said:At a quick glance it has all the hallmarks of a one pipe system.
FYI no it isn’t. Its under positive pressure. The only bit being 'sucked' is the few inches back to the air separator.doitall page 22 said:For your information only the pump is sucking the water from the boiler,
No.doitall said:We're not forgetting that everything electrically works as it should. because I don't think it does.
No. And so on..doitall said:If the boiler is making funny noises it suggests trapped air or scale.
Wouldn’t be as entertaining though.doitall said:The sooner you, stop thinking and leaving it to the pros the better your chances are
No, what you have Mattie is what I said on page 9:doitall said:What you have there matt!e is what we drew on page 12.
and4xpaws page 9 said:Its possible someone's tee'd the central heating return pipe into the primary flow from the boiler
4xpaws page 9 said:it could be set up flowing the wrong way through the boiler!
Not even yer mum would believe that!doitall page 12 said:4expaws mentioned what we later sketched out although I didn't read it.
Thanks. But ??..Mikefromlondon said:If I missed out 4expaws post, my apologies, but my acknowledgement must go to him obviously if he came up with this theory first, I secondede it. So acknowledgement or credit where it is due to 4expaws .
Re-read the last few posts on page 9 again!Mikefromlondon said:I read as many earlier posts on this thread as I could, and then I turned to last few posts on pages 9 and 10, and thought no one has been able to come up with anything yet.
4xpaws page 9 said:they're more likely to guess the wrong pipe as the boiler return.
