- Joined
- 28 May 2010
- Messages
- 110
- Reaction score
- 0
- Country
Hi all, i have put some rad flush in to try to remove this as a problem.
As the boiler kept going for 8 minutes when i turned the valve position 180 degrees manually with CH on, i thought i would try HW only, this turned the boiler off after about 30 seconds which suggests that the CH port is blocked, i am going to change the valve when i drain the system of the radflush.
But i also ran the system with CH and HW in mid position at 180 degrees but this did not heat the rads, the boiler would keep going for minutes on end then shutting down as if satified then starting up minutes later.
I appear to have found 1 problem but not the cure but i will only be sure when ive changed the 3 port valve.
