... I would not have commented on the details of a system I knew nothing about.
All my comments have been responses to what has been written in this thread, not to other sources of information.
AIUI it isn't possible. In the video the 'expert' makes this clear and I pointed that out in post #139.
As I said, my understanding was also that it isn't possible, and it's quite easy to forget what has already been written in a thread as long as this one, particularly when (as has been the case), my contributions have been squeezed in between lots of other jobs I've been trying to get done today!
As I have been discussing with Simon, I'm far from convinced that 'smart' domestic meters, as we currently know them, could ever be able do as is being suggested. As I have said, as I see it, it would require either separate half-hourly 'time-of-day' registers for each day (an essentially unthinkable number of registers), or else would have to 'tot up' actual costs (rather than usage), using the appropriate cost/kWh figure for each 30-minute period (which I doubt that people would trust - since the figures would be essentially uncheckable.
Is there another way? I suspect that the system as described would probably require more detailed records than just a lot of 'cumulative registers' which, as I understand it (maybe incorrectly), is all that current (and envisaged) 'smart' meters offer (and it is those 'more detailed records' that the likes of Simon seem to fear most).
This all started when you said that all generating systems have essentially identical costs.
I sincerely hope I didn't write that, since it is clearly nonsense. As far as I can make out, what 'started all this' was my statement which said ....
The concept of adjusting price dynamically on the basis of changes the supply/demand situation is, of course, questionable in many people's minds in relation to such a basic ('essential') commodity as fuel. It presumably costs little, if anything, more to produce electricity when demand is high in relation to supply, so such a system could presumably only be justified if it resulted in changes of usage patterns which were beneficial to the network (hence preserving customer's supplies) ....
... and my subsequent reference back to that statement, which said ...
... However, as I said, manipulation of prices in response to changes in supply/demand are not necessarily anything to do with increased production costs.
So, in attempt to clarify what I was trying to say .... what I meant was that,
at a particular level of total (satisfied) demand at a particular point in time, the cost of generation is the cost of generation (using whatever mix of fuels/sources is in use), regardless of how close that demand is to the maximum generation capacity available.
If, at some particular time, a high level of demand is approaching the the maximum generation capacity, and as a consequence the price is increased (for that time period), with the hope of reducing demand, that price increase has not got anything to do with the cost of generation (which is unchanged) but has everything to do with attempting to discourage use of electricity at those 'peak' times, in order hopefully to preserve customers' supplies.
Now you seem to be getting upset because I took what you wrote to be what you meant, when you now seem to be saying that what you meant was quite different from what you previously wrote (not merely worded in a less than ideal fashion).
I'm not upset - just, perhaps, a little frustrated - but that is a local forum thing.
As you may be aware, we currently seem to be enjoying a break (I suspect only brief!) from the presence of the person who appears to have appointed himself not only as the forum's 'headmaster', but also its police force and goodness knows what else. As a result, I was starting to enjoy what seemed to be an unusually pleasant weekend in the forum, without (as more usually would have been the case) being 'quizzed' about everything I write and being repeatedly confronted about 'what I had written'
I'm sorry that you unwittingly got rather entangled with 'local issues' in my mind!
Kind Regards, John
