- Joined
- 7 Sep 2022
- Messages
- 4,374
- Reaction score
- 1,247
- Country
Not even thinking?Now I don't do anything while driving
Solar produces nearly everything we have. It creates the wind, it moves the water and it spent millions of years creating the fossil reserves we're burning through.Solar produces no power
I think about you you know, every time I'm on site and have to use a tool that's tied to something by hose or lead, and it gets snagged on something or wrapped around something, or doesn't reach, or pulls the plug out of the socket 20m away down the scaffold, or I have to spend valuable working time just routing itIn the same way I avoid tools that use battery.
That doesn't sound likely to me. PV does give you a duck curve for power use but in the UK it is wind power that does the heavy lifting., at the moment high demand time is in daylight so charging over night we can have cheap power, but with the growth of EV's and use of solar panels this is likely to reverse,
You should have watched more of that myth busting video.an electric car has a 200+ kWh battery
No, you can't. There is no hydro power in the UK.
Wind generation comes and goes. The generation barely covers the maintenance for the turbines.
Solar produces no power at least 50% of the year. Of that 50%, power is generated only during the day some of the time. This is incompatible with the need for power during the night when most of the EV's are charging.
It does. Sun energy not reaching the ground/bricks and wasted results in greater need for heating for homes and buildings. Waste means higher demand for electricity.
Yes, the market factored these in, resulting in petrol and diesel being the most efficient fuel-based energies for cars. If the diesel is used for generating electricity for EV's, part of the energy in the diesel is lost to waste. There is less waste if the diesel is used for powering cars directly.
I started to watch a myth buster which was claiming mis information was holding back the take up of electric cars, I got half way through and not a single thing was said about any advantage in using electric powered cars, so clearly just a set of wingers.
The adverts are the same, not a single fact given, electric prices are soaring, so unless you can fit solar panels and charge at home, it is not going to work, I look at my own solar array and it is just about enough to run the house, it doesn't as the battery is not big enough, but if I doubled the size of my battery it likely would, but that would only be around 7 kWh, I average around 11 kWh per day from solar, and an electric car has a 200+ kWh battery, I would need a field at the back of the house filled with solar panels to recharge a car, so the power must come from the grid to recharge them, at the moment high demand time is in daylight so charging over night we can have cheap power, but with the growth of EV's and use of solar panels this is likely to reverse, so we are looking at a change in pricing in the future.
We have already seen a change, it was not long ago when super markets were offering free charging while you shopped, that's now gone, and we have seen charge points being turned off due to electric theft, so the gains with electric are being eroded.
Yes we have some batteriesYes, renewables are mostly intermittent in output. So... if only there was some kind of big battery that we could put in a car, so that we could store it for when we needed it, eh? Wouldn't that be brilliant?![]()
I had a Honda P50 which stated it would do 253 MPG at 15 MPH on a level paved road, which would compare well with my e-bike where a 48 volt 12 Ah battery will take me about 20 miles at around same speed, but the bike needs a lot more physical effort from me, and I would do 60 miles on a tank full Shotton to Towyn when I was a lad, there is no way my e-bike will last 60 miles, and it took minutes to refill the moped, it takes hours to refill my e-bike, and I could find filling stations along the way with the moped, but other than calling in at the railway where I work to recharge battery, I know of no where where I can refill my e-bike on route.Try driving ANY kind of ICE for 5p a mile!
Yes we have some batteries View attachment 318008 that can store a lot of power, and no lithium used. I remember visiting as a lad, with my dad who since he also ran a power station was taken on a personal tour, I think built around 1963 so I was around 14 when we went around, but can't remember much.
However in the e-bike favour it will fit in the car, my dad's latter Honda would, was it a Z50 or something like that, needed to remove battery, turn off fuel, drain carb, and fold handle bars, but needed a big car.
However to compare electric and liquid fuel one needs a level playing field, and most of the cost of petrol is tax, so not a level playing field, once we all have electric cars, I am sure they will tax the fuel.
I didn't know it myself. Apparently, EV drivers are seen as to$$ers.
All I have read up to date, you can't replace a single cell, it's an all or nothing job. All cells must be the same condition so it may be possible to make one good battery out of two, but one one would risk it.Anything amiss and you'll be contacted by the dealer asking you to come in and get it looked at, because it's in their interest to replace a couple of duff cells, rather than a whole battery under warranty!
E
Or the fact that he can't carry as much stuff in an electric truck because of the weight of the batteries, BUT the electric truck was going to be heavier and do more road damage.Sorry, but he's going to have to pick one or the other! Either he can't carry as much stuff for the same laden weight (in which case road damage won't be an issue), or he can carry the same amount of stuff but road damage will be greater, if the government were to raise the permitted laden weight. He can't have it both ways!
About the only thing he said that I agreed with, is that he didn't understand much about vehicle emissions...
If this is where you get your information, no wonder you come across as being so ill-informed!![]()
A few still buying ev's, so plenty still about.Every now and then, I wonder what kind of gullible to$$er falls for this rubbish
I have kept an open mind, however I started to watch a youtube video which was claiming most the negative comments are a myth, got half way through and not a single fact was given, and the same with adverts, it says "Who says" then does not give the answer.
But clearly after a bump the battery will need changing, so yes accident repair costs go up, so I looked up the price clearly varies, but looking at around £6000 so yes he has a point, slightest bump will cost over £6000 to repair.
But I still use an e-bike with a lithium battery.
www.reneos.eu
