OOI, what colours are your installation line conductors? (Ignoring 3-core cables for fans, 2-way switching etc)
As you might expect, 'a mixture' (and, yes, for what it's worth, there are labels to that effect!). It was obviously all red/black when I moved in, and a fair bit of that remains (although most of the imperial has now gone) but there's now also quite a bit in harmonised colours (installed during 2004, you will understand, or replacement of damaged cables during 2005-2013, or new cables on existing circuits thereafter!).OOI, what colours are your installation line conductors? (Ignoring 3-core cables for fans, 2-way switching etc)
I think you have to blame that on the fact that BAS apparently has not got a BYB (Amd3)t. I had been writing about 61439-3 (and Annex ZB thereof) until, just after midnight last night, BAS quoted 530.3.4, seemingly from his BGB (i.e. Amd1) (hence 60439-3 and Annex ZA), and when I replied (and subsequently) I just followed what he had posted, without realising that I was doing that!By the way chaps, 60439 was replaced by 61439 in 2009. Do try to keep up!
Pause there.As you might expect, 'a mixture' (and, yes, for what it's worth, there are labels to that effect!). It was obviously all red/black when I moved in,
Shame you could not have sourced red/black cable for the alterationsbut there's now also quite a bit in harmonised colours (installed during 2004, you will understand, or replacement of damaged cables during 2005-2013, or new cables on existing circuits thereafter!).
Not sur that metering makes any difference. Returning to my hypothetical 6 flats, 1A, 1B etc - if all parties were happy for the landlord to pay the electricity bill and give the tenants unrestricted/unmetered supplies as part of their agreement, and each flat had a CU supplied from a switchfuse in the basement , would you regard the flats as 6 single-phase installations, or as them all sharing one 3-phase one?my uncertainty relating to my place as it is currently set up is that there is a single 3-phase meter, and that could well be taken to indicate that it was a single 'installation'.
I have.I think you have to blame that on the fact that BAS apparently has not got a BYB (Amd3)
No problem. We've all ben there... Sorry. .... I even managed to create a post where I used both numbers, varying as I copied from different sources, and still not notice.
I suppose one could argue that - but, in any event, that was in 1987."Obviously all red/black"? Isn't there therefore an obvious lack of yellow and blue line conductors, and therefore an obvious lack of a 3-phase installation?
That is presumably essentially a rhetorical question (at least, you know the answer!). With the sort of exceptions you mention, all cables (other than distribution cables - as below) are T+E, and I'm not sure I would have been able to find black/blue or grey/blue T+E! Even the meter tails and distribution circuits are in red/black (insulated and sheathed singles). Whether any of that makes it three single-phase 'installations' in the eyes of BS7671, only "BS7671" could tell us! As I've already observed, their definition of "installation" is all but laughable, and certainly not helpful in this context.But (again ignoring 3C+E cables for fans, 2-way switching etc) did you use only brown for line conductors, or did you also use grey and black, on the grounds that yours is a 3-phase installation?
Again, as you would be only too quick to remind me, it's not what "I would regard" that matters but, rather, how "BS7671" regards it - and there is not enough clarity for us to know about that.Not sur that metering makes any difference. Returning to my hypothetical 6 flats, 1A, 1B etc - if all parties were happy for the landlord to pay the electricity bill and give the tenants unrestricted/unmetered supplies as part of their agreement, and each flat had a CU supplied from a switchfuse in the basement , would you regard the flats as 6 single-phase installations, or as them all sharing one 3-phase one?
You say there is no "clarity", but I truly do not see how a DB/CU with only single phase devices in it, and only one phase going into it, cannot, along with the final circuits coming from it, be regarded as an assembly of associated electrical equipment having co-ordinated characteristics to fulfil specific purposes.Again, as you would be only too quick to remind me, it's not what "I would regard" that matters but, rather, how "BS7671" regards it - and there is not enough clarity for us to know about that.
As I said, there is no clarity (particularly in relation to the definition of an 'installation'). Virtually anything could be regarded as "an assembly of associated electrical equipment having co-ordinated characteristics to fulfil specific purposes". Maybe I don't have 3 'installations', but actually 30, 100, or ..... ?You say there is no "clarity", but I truly do not see how a DB/CU with only single phase devices in it, and only one phase going into it, cannot, along with the final circuits coming from it, be regarded as an assembly of associated electrical equipment having co-ordinated characteristics to fulfil specific purposes.
You know the answer to that. However, as I said the BS7671 definition of an 'installation' is to vague that almost anything would satisfy it, and I haven't a clue what is 'intended'. At one extreme, as I said, I could argue that each of my final circuits was an 'installation' - but, at the other extreme, someone could argue that the totality of everything electrical within my house constituted 'an installation', and that one undeniably has a "3-phase supply".Have as many as you think you have. Then count how many are 3-phase.
No, but I do not see that regarding one SP CU and its final circuits as an installation is so outlandish that one should worry about whether the regulations intend that not to be the case.However, as I said the BS7671 definition of an 'installation' is to vague that almost anything would satisfy it, and I haven't a clue what is 'intended'.
Oh that's not extreme. An FCU supplying a fan could be an assembly of associated electrical equipment having co-ordinated characteristics to fulfil specific purposes. 2 x 2-way switches and a length of 3C+E cable could also be.At one extreme, as I said, I could argue that each of my final circuits was an 'installation'
They could.but, at the other extreme, someone could argue that the totality of everything electrical within my house constituted 'an installation', and that one undeniably has a "3-phase supply".
I agree - that would not be outlandish at all.No, but I do not see that regarding one SP CU and its final circuits as an installation is so outlandish that one should worry about whether the regulations intend that not to be the case.
Fair enough - consider that you have a single installation. OOI, which part(s) of it could be regarded as 3-phase?I agree - that would not be outlandish at all.
However, nor would I consider it to be at all 'outlandish' to regard the entirety of the electrical 'system' within a single dwelling as 'an installation'. Indeed, I suspect that is how most electricians would think of it.
