- Joined
- 11 Jan 2004
- Messages
- 44,062
- Reaction score
- 2,913
- Country
The answer to what?
Life, the universe and everything?
The answer to what?
If none of those things make any difference then none of them can be changing the number of phases in the supplies to the installations.As I said (and you quoted), as far as I am concerned it makes no difference to anything.
As I've said, as far as I am concerned the answer is 'no'. I can't see how my building can be said to be 'supplied' by something that doesn't enter it.Can you have a three phase supply with only one phase (+N) entering the building?
Exactly. That's precisely what I've been saying. If only one phase is connected to anything within the building, I regard that as a single-phase supply, regardless of what other (live or dead) phase conductors may physically enter the building.If none of those things make any difference then none of them can be changing the number of phases in the supplies to the installations.
You may only have a single phase installation but there are three phases there should you wish to use them.my view goes further than that. Even if all three phase conductors (all 'live') enter the building (and the cutout), if the DNO (or someone authorised by them) has not connected anything to two of the phases at the cutout, then I still do not regard that as a "3-phase supply"
I think that "You" probably ought to be "One" again!You may only have a single phase installation but there are three phases there should you wish to use them. Therefore, it surely must be a three phase supply.
Of course, but it is still there.Regardless of what enters the cutout (from upstream), if the DNO has only connected cable to one of the phase 'outputs' of the cutout, two of the phases are not "there should you wish to use them" - and one would require DNO permission and action in order to make those other two phases available for the consumer to use.
Can you have an installation with a 3-phase supply if the installation is only connected to one phase?Can you have a three phase supply with only one phase (+N) entering the building?
In a single installation?However, we've moved quite a long way from discussing my situation, since I do use all three phases that enter the building.
As I said, our views about this differ, and I don't think anything is to be gained by our both repeatedly re-stating our respective views.Of course, but it is still there. One's installation is single phase at present but the supply is three phase (there are three phases available) should the DNO be asked to reconnect it.
But what is the purpose of the unused phases?Of course, but it is still there.
Well everybody else is talking about the installation, since that is the issue.I am not talking about the installation but the building.
That obviously depends upon what one regards as an "installation", and your opinion obviously differs from that of a good few others. When I last looked at my Poll, your view was outnumbered 9-2 (and that's without a vote from myself, so effectively 10-2) - the majority believing that my house has just one "installation".In a single installation?
