Jonas posted
Has this been updated to the Building Regulations G3 guides yet?
Do you have a link?
From what I've read at the moment it gives notes on extra safety devices relating to thermal stores which are over 500l/45kw.
No3 would imply a normally open motorized valve would be needed.
What are nu heat using?
If this second valve is spring loaded closed then it has to be held open permanetly using energy and only close in the event of the store reaching 90c which may never happen.
Who makes this ferking crap up?
If its an integrated ch/hw store then how does it work?
It would be easier to fit a large vertical commercial hydraulic decoupler and by-pass this crap. Just get a company to build you one big enough with a big nameplate stating- Hydraulic Decoupler.
1. The control thermostat operating a normally-closed zone valve will allow up to a maximum temperature of 65°C
2. A manually resettable over-temperature cut-out (limit stat) also operating the zone valve will switch off when the temperature rises to 80°C, and
3. The second manually resettable over-temperature cut-out (limit stat), operating the second zone valve will switch off when the temperature rises to 90°C. The second limit stat and zone valve are additional to the previous supply.
Do you have a link?
