Since most of them will probably get asylum anyway, why would it deter them?
If it is so very obvious - put yourself in their place and ask yourself why you might risk your life in a small boat, to cross a busy and very dangerous channel.
Source? Obvious doesn't mean right. After all making drugs illegal will stop drug use won't it.It is mostly males making the trip by a very large margin. Why does something with so obvious an outcome, need to be modelled at all? It is simple common sense that it will work as designed. Some things are obvious, some not - this is one is obvious to work.
Because it's the only practical way to make an asylum claim in the UK?If it is so very obvious - put yourself in their place and ask yourself why you might risk your life in a small boat, to cross a busy and very dangerous channel.
It would appear Boris nicked the idea off Tony Blair.
Labour's 'embarrassing' hypocrisy as Blair's plan to send asylum seekers to Africa unveile | UK | News | Express.co.uk
Here we go again - as it says considered and didn't. Seems you can't read when you do find info.
This time it's an announced intention that as yet hasn't happened.
Only because Tanzania turned him down.
I don’t believe that’s really the same thing at all.
It was looking at sending failed asylum seekers to Tanzania. In fact specifically Somalians.
It is not the same thingAnd processing asylum seekers. It's exactly the same thing.
and currently are. It makes the whole idea dubious and just a political thing to do that makes little difference - other than reducing the number of boats and very possibly people who are aware that they are not refugees.claim rejected and is waiting to be deported
Because they will be in Rwanda and have asylum there. It is a perfectly safe country to be in, and if asylum was their goal then they should be very happy (even the UNHCR send refugees there) But a perfectly safe country is not their primary goal (they were perfectly safe in the EU) they're after British citizenship but unfortunately for them they are too late our little island is full.Since most of them will probably get asylum anyway, why would it deter them?
Yes. I wondered what was going on in Yemen. Some terrorists there aren't now and up pops a map of the set up, couple of areas of IS control. USA trying to get Israel and several arab countries who don't entirely get on well to work together. IS seems to be active in Africa as well.religious and political nutters.
You can't assess whether anyone is a true refugee until they've been assessed.
