T&E in conduit in screed?
As already mentioned, screed trunking. It's wide and shallow, and has fittings to bring it up out of the floor.
It's also (if you buy the right stuff) galv steel, which when earthed properly will give you mechanical protection for the cables.
... galv steel, which when earthed properly will give you mechanical protection for the cables.
Whilst I agree with the spirit of what you are saying/suggesting, your wording could perhaps have been better, since I'm not sure that galvanised steel offers any more 'mechanical protection' when it is 'earthed properly' than when it's not earthed :)
Kind Regards, John
I also wondered. Then I wondered whether they really are '5 circuits' in the sense that you and I would mean - it is possible that there are 5 'feeds' (to different things/places) from less than 5 actual circuits.
Kind Regards, John
In which case it could be done with two by 1.0 mm tripple and earth cables. One common neutral and five switched lives. Might get those in.
I almost mentioned that, but it's not really desirable to have L and N currents to a load travelling in different cables. The ideal would be 7-core cable (one N, 5 switched lives and an earth).
Kind Regards, John
Kind Regards, John
Can't really see a problem when they are both in the same conduit.
Probably not. To be honest, it rarely produces noticeable problems even when the cables are widely separated, let alone not in conduit. However, it remains a theoretically undesirable practice.
Kind Regards, John
Kind Regards, John
Correct, 5 feeds not circuits. I've cut it down to 4 now.
4 different switched lights.
That did occur to me today :whistle: You are correct, the mechanical protection is the same whether earthed or not - but if it's not earthed then drilling and screwing through it could make it live. It's most likely that the circuits will be RCD protected - but if the trunking is earthed then the cables within it don't need to be (though elsewhere they probably will).
Something I have noticed in recent times, 32mm or 40mm waste pipe is being laid in for this purpose. On one job there were 5 or 6 such pipes emerging from the floor.
