You presumably mean 32A (or 30A) socket circuits - since they can be just as needed on a 30/32A radial as a 30/32A ring final.FCUs were invented because we have 32 amp ring finals ....
Kind Regards, John
Why is local isolation needed for an alarm system?
I suppose I wasn't thinking of commercial installations where it might not be convenient to isolate the circuit.We have had a few instances where alarm engineers would not change there panels as they could not isolate the panel supply and its also a specific requirement for fire alarms. though a key switch is now the required way.
Flats are a different matter, such as the ground floor with the washing machine socket which remained live even with the CU switched off.Every circuit in a house can be isolated either with a MCB or pulling a fuse.
A typical BS1362 fuse will have no discrimination against a 6 amp MCB
I have known "engineers" (not just alarm ones) be adamant that they want local isolation for the bit of kit they are working on. They don't want to responsible for isolating a whole circuit in case something has a hissy fit when the circuit is re-energised.I suppose I wasn't thinking of commercial installations where it might not be convenient to isolate the circuit.
What about in a house, though?
What you have been showing me are the regs. The regs are not BS 7671.
Has it occurred to you that to insist something must not be done because it might be removed from the regulations in the future is, shall we say, a little light on rationality?Has it occurred to you the regs may have made another mistake that could be rectified in a future amendment?
Yes, that's fair enough and, as I said, some things are a good idea.I have known "engineers" (not just alarm ones) be adamant that they want local isolation for the bit of kit they are working on. They don't want to responsible for isolating a whole circuit in case something has a hissy fit when the circuit is re-energised.
The Live is removed that way, the Neutral remains connected. With the Neutral still connected the circuit is not isolated. ( that is my opinion )
And you were wrong to say that.I didn't say it was not allowed. I said there was never, ever, a reason to do it.
Supply needed in loft and there's no accessible "power" circuit.
Or, as I've witnessed recently, supply needed but the power circuit is inaccessible because of the use of the modern crap non-liftable flooring. In this case, to have accessed a "power" circuit, it would have meant making swiss cheese of the flooring in a new build - the cable would have needed to go through half a dozen joists and at least one noggin, and that would have needed quite a lot of holes cutting and fixing up again afterwards.
You can argue as to whether ripping a house apart (or rather, avoiding the need to rip it apart) constitutes a "good" reason, but it IS a reason.
What if the item you want to supply has a wall wart power supply? Not all, but some boosters do.Presumably only a small load is required in the loft. Therefore I repeat that there is never, ever, a reason to put a 13 amp socket on the lighting circuit. For a small load you can use a clock connector, a BS546 2 amp socket, or a BS546 5 amp socket.
