- Joined
- 6 Oct 2024
- Messages
- 19
- Reaction score
- 0
- Country
Shall do but will be later - grateful for your helpful comments
OK, I'm pretty sure that the Wilo is (knob) set pointing to the right, constant pressure, if so, next time its running, turn the knob almost fully anticlockwise, (proportional pressure) as you are turning it you will see the pressure setting changing, (it can be set incrementally in 0.1M steps), keep adjusting it until you get 6.0M, note the power in watts, see does the noise abate, the newer versions of these pumps also display the flowrate in m3/hr. have a look out for it.On the Wilo, there should be I,II &III, in the middle, with houses to the left and right, is the setting knob pointing to the left or to the right?
I thought you said it was set to your large house!!, OK, just try it as I suggested above, you are trying to get it to satisfy both a very small flowrate on UFH only and a fairly high flowrate on rads, these are a fabulous pump with all those incremental settings.Wilo was pointing to right but to Number 3 setting!!
Afraid that makes little or no sense thermodynamically.I checked the burner in my garage and it efforts says RDB 2.2BX V26-46!
Turned Wilo pump dial on the return to the boiler anticlockwise until it showed 6.0.
The wattage ranges from 49w to 61w.
The boiler has been firing for nearly 2 hours on UFH only and is now firing on for 2-3 minutes (5min one time) and is off for just over1 min - the firing time has lengthened! Manifold shows water in at 50c and return at 45c. What do you think? Oh, extremely grateful for your time and help!!
Oh, the dial on the Wilo pump is on the left at image of middle sized house
