I did think about it but, better not.
You may be happy to try the following (without having to open up the machine!). I don't think it's going to help me, but it would be interesting and, if you do it, I'll explain why ...
1... Starting with the machine off. Hold down the F2 key whilst switching it on. Keep holding the
F1 F2 key until something appears on the screen and report what that is (it may only appear on the screen briefly).
2&3 ... Repeat (1) using F3 and F4 keys respectively.
4... Repeat (1) using F1 key, but this time, if the initial "display test screen" appears and persists, release the F1 after a few seconds.
As for other continued playing/pondering ....
I have now realised at least one reason why the internal fuse is 'hidden'. Since it's in series with the L-lead, and is in just a bare 'skeleton' fuse holder, it would be 'live' if an L-lead were plugged in and connected to the L of an installation. In contrast, the user-accessible fuse (in the 'battery compartment') is in series with the PE lead, and hence will usually be safe to touch. This illustrates another difference between the N and L+PE lead sockets - the N is not fused, but the other two are, and the fact that only L and PE ones have 'lead present detection' might be in some way related to this.
If I remove the
PE fuse and then switch on, whether I have leads plugged in or not I still get the "LEAd" message (not the Err1 I get if I remove the L-fuse with leads unplugged). However, if I unplug the PE lead (but not if I unplug only the L-lead), I
do get the 'relay click' which I get when the Err1 message appears (with L-fuse removed). You tell me
Kind Regards, John
Edit: Typo corrected
