New to posting on this forum so hopefully without getting an earfull...
fuzzytrifle - top right of the plate identifies a 3 phase 50 htz motor, links shown connected in star.
If your replacement motor shows the same, connect it with the links and wires exactly as the old and it should be good to go. It may go the wrong direction, if it does swap 2 of the wires on the motor. If the plate on the replacement motor shows 230V 50 htz do not use it, you have the wrong motor.
Oh, by the way,
star - high current, low speed,
delta - low current, high speed.
Motors that use star/delta starting are run in star initially to aid starting.
Oh, by the way,
