Nor should it - it should hold the peak reading. It should show around 140 to 180 PSI, after a good strong pull on the starter.Borrowed a compression test & after 3/4 pulls tester needle doesn’t move.
Head off & don’t see any issues with the position, valves etc & no scoring in the bore.
Short video clip which after two cycles of the valves opening & closing you will bear the smaller valve “inlet ?” Click ???
Valve clicking video.
The needle didnt even move & if it did its minimal.
Ok think we are getting crossed wires.
I mentioned about no compression THEN i took the head off.
If compression was there then the gauge would show it.
