You should do! The boiler is a Glowworm Ultracom 38hxi (page 1). A quick look at the MIs will show you that this boiler does not have an internal pump.Six pages on and I still don't know if this boiler has an internal pump !
I agree. This needs to be dealt with urgently.Its not correct to run the system with TRVs on every radiator and just rely on the boiler to cycle. There should be a room stat to actually turn it off.
Again, I agree. It's in the MIs.If there are TRVs on every rad then the system should have an ( auto ) bypass.
as above from lcgs I recommend you call out an engineer familiar with these boilers but first try these settings
d0=30
d1=10
d71=75
the password for level 2 access is 35. I would say the primaries must be at least 28mm upto the controls (motorised valves) and you will need the pump lcgs quoted. The pump must be on it's highest setting.
The undefloor heating should be timed for at least 16hrs a day in the winter too.
d1 - I can't change this as there is no control cable for pump overrun.=-Well, I could change it but it wouldn't help much.
There is no d71 in the manual...
alot of knowledgeable guys have thrown there thoughts in on this but its utterly useless if the OP isnt going to give the complete picture or answer guys questions. as DM said above you need to find a competant GW specialist in your area, try GW themselves. anyone half competant would know these have to have the pump wired directly from the boiler. it seems the system is beyond an easy fix and needs some proper attention.
