Well my condenser sits quite happily with a delta between 21 and 35 degrees. I can run it in a variety of ways, with the store cooler than 80 should I wish. The PHE is rated at around the 100kW mark, so I cold quite easily get a respectable performance with a store temperature in the Mid 70's....In fact here is part of the spec sheet for it:
I am not lecturing you on energy efficiency. Merely that TS are perfect for a condenser.
My store came with dual stats which I can set to ensure a return temperature below dew point and minimise short burns. Currently though I have a sensor communicating between boiler and store which has similar buffering characteristics but allows closer monitoring of the boilers various sensor curves through software.
I can assure you it condenses rather a lot.
The radiator circuit can come off at various points in the water column giving some control over flow temperature, but frankly with a modulating pump, full TRV coverage (except where the room stat is) and heavily lagged pipes, WC is not the be all and end all as the boiler's burn is regulated by the store.
Oh, and on mine, the only blending valve is the TMV valve coming off the plate - 'cos I don't want water hitting the taps at 70 degrees
I accept I should have said boiler efficiency rather than cylinder efficiencies, but if you want to heat a cylinder up quickly and to 63 degrees, then no steamer is going to condense anywhere near as long as a steamer on a properly set up TS.
I won't lecture you if you won't lecture me eh?
*edit* my store is set as hot as it likes until the bottom third hits around 55. This is sensed by the boiler's dedicated cs. The flow temperature is limited by the boiler PCB to 84 IIRC.
side 1 side 2
Inlet temperature : 75 °C 5 °C
Outlet temperature : 30 °C 50 °C
Flow rate : 1.938 m³/h 0.5317 kg/s
Plate heat exchanger
Heat load : 100.0 kW
Total heat transfer area : 0.836 m²
Log mean temp.difference : 25 K
Calculated pressure drop : 13.6 kPa 12.7 kPa
Number of channels : 19 20
Number of plates : 40
Overall HTC : 5100/4780 W/m²,°C
Oversurface : 6.7 %
