In fact, just before the turn of the 1960s our electrical practices were so crude and unsafe that the local council had to send blokes out to sweep the bodies off the streets every week
They and most others are designed for these: https://www.primetools.co.uk/produc...de-insulated-modulo-terminal-screwdriver-set/impossible to find either a straight or cross head driver which properly fitted the terminal screws.
That saves me digging mine out and taking picsThey and most others are designed for these: https://www.primetools.co.uk/produc...de-insulated-modulo-terminal-screwdriver-set/
Hmmm - I suspect that's a new one on a lot of us.They and most others are designed for these: https://www.primetools.co.uk/produc...de-insulated-modulo-terminal-screwdriver-set/
That's a bit of a surprise as they've been around for so longHmmm - I suspect that's a new one on a lot of us.
... so what type of head do the device terminal screws have - and why on earth aren't they a standard type,to correspond with the screwdrivers and bits which most people (I suspect including most electricians) actually have?
I don';t think it is - a dual-RCD board is a dual RCD board, and has two neutral bars (one for each RCD).I do not know why a dual RCD board is referred to as "High Integrity" !
Maybe, but what sort of screwdrivers have most people (including electricians0 been using for 'device terminal screws' for all that time?That's a bit of a surprise as they've been around for so long
What a strange question - because you didn't know about them.Maybe, but what sort of screwdrivers have most people (including electricians0 been using for 'device terminal screws' for all that time?
This extraordinary term "high integrity board/CU' (don't ask me ) seems to refer to a board which has two RCDs, but also has provision for a few (often only two) non-RCD circuits - hence three neutral bars.
As it happens, most of thee CUs in my house are these 'high integrity' ones!
Kind Regards, John
The bars and terminals can, of course, be rearranged as appropriate.This one has 7 neutral terminals on the none RCD circuits - main neutral in, loops to the two RCD's, 4 available for sub-ciruit use.
Fair enough - but it doesn't alter thee fact that I have never heard of them, nor any mention of them in discussions (real or 'virtual'),despitee the fact that, even here, there are quite often discussions about 'tools for electricians', and I've never heard them mentioned in any of those discussions. All we generally hear about are "VDE" ones, and they almost invariably come for use with standard slotted and Phillips headsWhat a strange question - because you didn't know about them. I obviously do not know the answer regarding most people - but - I have had them for a very long time.
I'm afraid that that attempt at an analogy is rather lost on me. It's all very well telling me that I 'should' use the proper screwdrivers, but sisnce I hadn't heard of them, have never previously heard any mention of them and hence didn't know they existed,I've hardly been in a position to put that 'should' into practice!It seems similar to your view on DIYers not testing their work but that doesn't alter what should be done.
Are you sure?I don';t think it is - a dual-RCD board is a dual RCD board, and has two neutral bars (one for each RCD).
See aboveThis extraordinary term "high integrity board/CU' (don't ask me ) seems to refer to a board which has two RCDs, but also has provision for a few (often only two) non-RCD circuits - hence three neutral bars.
Kind Regards, John
I have mentioned them a few timesFair enough - but it doesn't alter thee fact that I have never heard of them, nor any mention of them in discussions (real or 'virtual'),despitee the fact that, even here, there are quite often discussions about 'tools for electricians', and I've never heard them mentioned in any of those discussions. All we generally hear about are "VDE" ones, and they almost invariably come for use with standard slotted and Phillips heads
I
