- Joined
- 7 Jan 2010
- Messages
- 13,418
- Reaction score
- 3,340
- Country
The heater will be outside so it shouldn't matter what fuel you use.Do Kerosine heaters not cause over condensation and also are smelly?
Assuming you are paying around £1.75 per litre, its going to cost about 13p per kWh vs about 9p with LPG.
If you live near a marina or yacht haven you could get your fuel 100% heating duty.. roughly £1.40 per litre.
Garage I use has an ancient waste oil burner that looks like a small wood burning stove. Pumps out a lot of heat for it's size. Of course the oil is provided free by customers having oil changes, so zero running costs.
On a higher setting more diesel is burned!A kWh is a kWh
And more kWh of heat output is produced.On a higher setting more diesel is burned!
Correct, but at what cost which is what the OP is asking.And more kWh of heat output is produced.
On a higher setting more diesel is burned and more heat is produced.Correct, but at what cost which is what the OP is asking.
It will be in the closed space of the shed / workshop. Paraffin price has gone up too I gather.
The exhaust goes outside
I have read about extending the exhaust pipe around a room before exiting outside thus using the heat from the pipe to add heat to the room. Another idea was to run through a radiator, that one I have doubts about.Yes, Diesel heaters exhaust go outside in pipes.
When I said use kerosene, I meant use it in the diesel heater instead of diesel.Yes, Diesel heaters exhaust go outside in pipes. Paraffin heaters don't have exhausts, hence severe condensation in the room and fuel smell when starting and putting off.
