Some people are heating their house with diesel heaters.
Won't the perceived benefits be obviated by the transport costs of the Chinese diesel?
I see a lot of youtube videos on Chinese Diesel Heaters.
Anyone using one? How do they rate in heating performance, safety and fuel cost savings?
Some of the cheaper ones might burn old engine oil, but this may require a license.I'm no looking for a cheaper source of fuel for it, than diesel. I read some people run them on kero/heating oil, but where to source that from, at heating oil prices?
Red diesel?I'm no looking for a cheaper source of fuel for it, than diesel. I read some people run them on kero/heating oil, but where to source that from, at heating oil prices?
Red diesel?
They sell them as 5kw-8kw, but they won't be that. As I understand it they are a copy of the eberspacher d4, which is 4kw.As mentioned else where, I've been quite interested in one of these, at least as a cheap way to put some heat in my outdoor workshop, during the winter. Well, I finally bought one. This one for £67.49, 8Kw.
I mounted it in a corner of my big workbench, blowing its exhaust out through the back wall. It included one of the better controllers, plus a remote control. The controller, has I eventually discovered, included a temperature sensor and thermostatic control. Very effective, apart from the fact, the stat could only turn the heater down to minimum output, rather than off. The other option is to simply set it to a preset power/heat output level.
On full output, the hot output duct quickly becomes hot enough to burn the skin of your hand.
So I'm quite pleased with my buy.
My outdoor workshop, is an extension on the back of my garage, open to the garage. Rather than attempt to heat the entire space, I've added some curtains between the two, to at least retain the heat.
I think boat diesel is the same as tractor diesel. As well as refuelling jetties, you can (could) get jerrycans filled at some fuel suppliers in boaty areas.
