If additional sunlight is reflected onto it, yes.If sunlight is reflected onto a solar panel using a mirror, does it generate the same amount of electricity as sunlight shining onto a solar panel directly.?
I think he's asking whether reflecting light onto a solar panel has the same energy efficiency as non-reflected light. Even the most efficient mirrors won't reflect 100% of the light they receive so it will always be slightly less energy efficient to reflect light onto a solar panel than replace the mirror with a panel instead.If additional sunlight is reflected onto it, yes.
It’s disgusting what they are doing, absolutely disgusting:You are going to explode if you keep on with this. Seriously, have a day off.
I suspect you will find they are spaced not to shadow each other with the sun going from one horizon to the other or at least that factor is considered.But they tend to use the sun to heat water to power steam turbines. Mirrors are used in some installs to reflect light. But typically its easier to just add more panels where the mirrors would be.
Solar Thermal systems are very clever, but their return is typically poor compared to PV. Plumbers are expensive.I suspect you will find they are spaced not to shadow each other with the sun going from one horizon to the other or at least that factor is considered.
The mirror system that is used has a parabolic mirror to concentrate heat for heating a fluid to drive a steam turbine.
The hot water system places like Turkey use is actually a pretty good way of doing it. No moving parts, just a thermo syphon. Ultra cheap. There set up uses something much like an oil drum on the roof. Probably scope for improvement via different shapes but if it works...............
Final warning. It’s going to happen. Be careful otherwise….It’s disgusting what they are doing, absolutely disgusting:
Liz Truss campaign’s biggest donation came from wife of former BP executive
Fitriani Hay, wife of James Hay, donated £100,000 to Truss’s successful bid to become PMwww.independent.co.uk
Prices are high due to the £500 billions of funny money printed for covid, and now they are doing it again.will cost the tax payer/future tax payer. North of £100Bn.
Is solar power any good for industrial use? Big 3-phase motors and the like?I keep looking on Google Earth at the huge swathes of industrial buildings with huge white roofs reflecting all that sun light.
There is surely scope to use those roofs for solar energy.
Every town had its own gas works, producing gas from coal. After they were demolished and cleared, many of the sites became shopping centres. Many of those shopping centres are now being demolished and cleared...I remember the days when all our gas came from coal
Turkey appears to have lots of flat roofs and plenty of sun. Heat ability is is probably like frying eggs on the ground in Death valley. While the air is hot it's not that hot.but their return is typically poor compared to PV. Plumbers are expensive.
They generate at 690 volts, so yes.Is solar power any good for industrial use? Big 3-phase motors and the like?
Although back then suicide rates were through the roof because it was so easy to top yourself by sticking your head in the gas oven and breathing in those noxious coal derived gases.Every town had its own gas works, producing gas from coal. After they were demolished and cleared, many of the sites became shopping centres. Many of those shopping centres are now being demolished and cleared...
