- Joined
- 7 Sep 2022
- Messages
- 2,829
- Reaction score
- 730
- Country
Make sure you only use OEM screenwash straight from the dealer and keep all the receipts to prove it; you don't want to invalidate your insurance by grabbing some from AsdaDisappointed that it still uses about the same amount of screenwash as my last ICE though
Maybe buy warm white LEDs if you're after a psychological effect that encourages you to turn the thermostats down. You can also get LED that get warmer as they dim..heat from tungsten lights since in the main inferred, reduced the air temperature required for comfort
Where are you getting your numbers? Is it an objective source? Does it accurately balance up the opposite side e.g. the number of successful charges that occur daily? So far I've only seen similar as unsubstantiated claims from an ignorant fewwhy do so many complain of the concern of running out and being able to find anywhere at all to charge?
If you could handle the effort of planning ahead and leverage their delivery service it'd take you 30 seconds to walk to your letterbox?On car, it's less than 1 hour. It all depends on how much effort you can handle
