We know when they were found and where they were found. The impact of the tidal stream, entirely depends on when propulsion failed and if they had more ebbs than floods. From the photos of the "dingy", and reports it was DIY 10m inflatable with flimsy PVC pontoons and no reinforcement anywhere. 2.3 tonnes of human cargo squeezed into/onto that.
I've produced two models, with propulsion failure around midnight and the other 2-3 hours later. The shorter model shows they would have been pushed slightly towards UK waters. The longer shows no more than 1-2 cables SW.
We also have the recorded mayday relay from cap gris-nez, who were coordinating the rescue. If this was the genuine full message its highly unusual.
It is normal for a mayday relay to give a location or last known position and time. This is essential for any SARs operation.
From location of the survivors at the time of pickup, you can plot their approx position by each hour back.
Dover <M> tidal stream (the closest to their known position).
2332 slack
0004 turn 0.7 SW (approx 15 mins)
0232 1.68kts 46º
0552 turn 0.5 SW (approx 15 mins)
0632 slack
0649 turn 0.5 NW (approx 15 mins)
0952 1.76kts 233º
1152 slack
12:13 turn 0.7 SW (approx 15 mins)
1452 1.68kts 46º
Given it was roughly 80% of a spring tide, the NW/SE turn points last barely 15 minutes before / after each slack tide and these are the peak flows.
If they lost propulsion before midnight, they will have been pushed back 0.1-0.2 NM Maximum. If they lost it later, the tide would take them slightly closer to the UK.
Who's to blame:
Traffickers - boat was massively overloaded and highly unlikely to be safe for 34 people.
Adult Migrants themselves - You don't have to be an expert in boats to know that 34 people in a home made boat in cold water attempting to cross 20-30 miles at night is stupid.
Coordinating rescuers - might have some learning, based on the mayday relay. But then if the Illegals were fibbing about their location, how the hell can someone successfully search for them?
The argument that French rescuers were busy and UK weren't is nonsense. This is one of busiest shipping lanes in the world. Standard procedure is to task local vessels. Based on the Mayday relay they had no idea where the MOBs were to task anyone.
However, once you say ""All ships in this area are requested to have a sharp lookout to proceed to this area to take contact and report any information to
Gris-Nez emergency coordinating this operation." You are in charge.
Rather than itemise your comments, as I would normally, I'll respond to the whole.
Yes, we know where they were found, and when they were found, about 9 nautical miles from Calais, and at that point the dividing line is only about 10 nautical miles, so they were about 1 nautical mile inside French waters. from previous estimations, we can assume that they were under way from about 20.00 hrs Evening of 23rd) until about 01.30 hrs, (morning of 24th) some 5.5 hours. We have a report that they first called for assistance at 01.30, but they were still underway.
There is no report at all, that power was lost at about midnight, so your model is solely your creation. There is a report that they were still under power at 01.30hrs.
You previously estimated their journey to be about 40 nautical miles from Dunkerque. Sailing at about 5 knots (your assumption) for 5.5 hours would give their position in British waters, NW of Calais, about 27.5 nautical miles into their journey. For sure there would be some wind and tide influence, but I think we can safely assume that they reached British waters, NW of Calais.
See diagram with black spot showing midpoint of journey, i.e. 20 nautical miles. (47 miles is about 40 nautical miles) red cross indicates approximate boat position. The faint grey line indicates the dividing line.
What we also know is that they left at about 20.00 hrs British time, coincidentally around low water point, for Dover, so low water for Calais or Dunkerque would be an hour or so later.
We know from previous discussions that the tide in the Channel does not flow back and fore between UK and France.
It flows in a NE, SW direction, and the tide time between places in UK and France are about 1.5 hours difference. France being slightly later than UK.
Dover Tide Times - free 7 day tide predictions for Dover with historic high and low tides, sunrise, sunset and phases of the moon
www.tidetimes.org.uk
So there was a flood tide in the Channel with water flowing in a NE direction, but this flood tide would only start to affect them around 1.5hours before high water, i.e. around midnight until about 05.00hrs in the morning of the 24th.
The 'Dover Strait' is a narrow area of water between the English Channel and the North Sea. The water flows in from the English Channel for approximately 6 hours on the FLOOD TIDE to spread out in the North Sea, then stops, turns around through 180°, and flows back from the North Sea for approximately 6.5 hours on the EBB TIDE to spread out in the English Channel (imagine the old fashioned hour glass with the sand flowing through the restriction in the middle). As an approximate guide we can say that, at Dover:
- The FLOOD TIDE flows from the South West from 1.5 hours before HIGH WATER to 4 hours after HIGH WATER DOVER (followed by a short period of 'Slack' water).
- The EBB TIDE flows from the North East from 4.5 hours after HIGH WATER to 2 hours before HIGH WATER DOVER (followed by a short period of 'Slack' water).
A chart and satellite map of the Dover Strait where channel swimmers cross.
www.queenofthechannel.com
Then they were subjected to the reverse ebb tide, about 4.5 hours after high water (about 05.00hrs) until about 2 hours before the next high water, ( about 11.30hrs) Then they would have been subject to the flood tide from about noon on the 24th, until about 17.00hrs on the 24th. But they were found at about 14.00hrs, before the flood tide had affected them as much as the ebb tide had.
So it's perfectly possible that the ebb tide could have taken them closer, and back into French waters.
In addition there was a northerly wind blowing, which, if it had any effect, would have blown them toward the French coast.
Therefore it's perfectly feasible that they made it to British waters, just, and the tide and wind caused them to drift and be blown back toward the French coast.
But, as I said, it's probably marginal, but that does not excuse either SAR service launching a rescue attempt.
