Fair enough - so (not for the first time!) the wording of BS7671 seems a little on the silly side!I don't know, but both the definition in BS7671, and BS EN 61439-3:2012. Low-voltage switchgear and controlgear assemblies. Distribution boards intended to be operated by ordinary persons (DBO), require that a consumer unit is type-tested.So when BS7671 effectively says that ("if under the control or ordinary persons") it must EITHER be a ('type tested', per definition) CU OR be compliant with BS EN 61493-3, what do you think it is trying to say??
Kind Regards, John
